J_VTEC
Hi All,
I was topping up my washer fluid today when I noticed what I thought was a random bolt lying on top of my cam cover. When I picked it up, I realised it was actually the head of one of the bolts that fastens the cam cover down.
Now there's a bit of moisture around the cam cover gasket on that corner of my engine (which I already knew about). What I want to know is...
1. Can I take the other 5 bolts out and remove the cam cover to get at the sheared bolt? (I'm thinking the cover should just lift off the sheared bolt thus exposing more of it which I can then get hold of with some grips or something?)
2. Will I have to drill the thing out and get the head re-tapped?
3. As there's not much of a leak, just leave it?
Any help, advice or suggestions would be greatly appreciated.
Many thanks
Many thanks
