Hi Guys,
This is a great resource. Thanks for doing it
Ok so I haver a 7th Gen diesel with 290,000 miles - yes you've read it correctly
Love this car.
So there's a noise coming from engine which sounds like timing chain issue etc.
However it isn't really there when running cold and sometimes it's far less pronounced when running hot.Also seems to be distinctly in the area of all the pulleys - although it isn't an issue with any of them.
I'm presuming it's a chain issue but seems odd to not have a constant rattle!! You would think it would't matter - once it's worn it's worn right? What difference should the temp make etc... Noise comes and goes to varying degrees and is never loud on start.
Chain and injectors etc. all done at 115000 by Honda under the revised warranty that covered fault in this area.Always serviced with correct oil at 5000.
This is a 2004
Anyway any opinions are always valued.
And yes - I'm keeping the car
Sean
This is a 2004
Sean
