I'm having a recurring nightmare with flat battery issues.
Had a problem while driving car about 9 months ago when it wasn't charging. Had to jump start it from another car, then driving home dash was throwing every fault light available. Took it to local garage and they replaced the alternator and the battery. All good.
About 3 months later, battery went flat again. Thought is might've been too many short journeys so charged it and it was ok for a day or so then went flat again. Took it back to garage, they said the alternator to battery lead was corroded, cleaned it and remade the terminal connections. All good.
Now it's doing it again. No battery light illuminated on dash, but battery goes flat after a few days of driving. Borrowed a multimeter to check voltage with engine running, but it just varies between 12.3v and 14.2v. one minute it seems to be charging, next it isn't.
Voltage drop from alternator output compared to +ve battery terminal is 0.5v, which is apparently ok.
Could this be the ELD faulty? I've read about it online but don't seem to be able to establish any particular symptoms to look for, and all the stuff about it is USA based so I'm not sure I've even got an ELD. Worth changing it anyway?
Help gratefully received
