Attenzione
Hi Accorders.
Few days ago i got check engine on and read faulty code. I have cleared codes and 2-3 days driven ok, but today got check engine again. Later today i will read codes again. But i think those will be the same, as symptoms is exactly the same. My car becomes vegetable no turbo, no more 2000 rpm (btw Accord 2.2 diesel 2004)
i have read about those codes in google, but maybe someone can advise, before going to service. Seems it's not permanent error, because first time it was 3 days ago, but second it's now.
Ou, more info, after an hour of idle, my ecu seems took pity on me and enabled turbo and rpm but check engine of course still present
codes:
codes:
Code:
meta-info header:Error Codes
file version:1
type:5
time:1403712682223
codes:P1069,P0069,
codes_p:
codes_raw:43106900690000
codes_p_raw:NOTSUPPORTEDNODATA
Error Codes
P1069
P0069
Manifold Absolute Pressure - Barometric Pressure Correlation
Vehicle speed (Speed) 8 mi/h
PIDs supported [21 - 40] 00100000000110000000000000000000
Intake air temperature (IAT) 80 °F
Engine coolant temperature (ECT) 131 °F
Fuel Rail Pressure (diesel, or gasoline direct inject) (FRP2) 0.9871668311944719 Atm
MAF air flow rate (MAF) 5.27 g/s
EGR Error (EGRE) 0.78 %
Calculated engine load value (EngineLoad) 30.98 %
Commanded EGR (EGR) 45.88 %
Engine RPM (RPM) 812 rpm
Intake manifold absolute pressure (MAP) 1.441263573543929 Atm
