simovtec
well after deciding that the accord dash bulbs were next to rubbish i decided to change them to LED'S...
had a wee look on here and someone had already posted regarding it... but they posted the wrong size of bulbs which are too big and wont fit into the board..
THE BULBS REQUIRED ARE 286'S!!!!!
Started with removing the plastic dash.. them simply 4 screws and pull the clocks out.. you them remove the 3 plugs from the top of the clocks so it can fully be removed..
Flip it over and you can see the bulb holders.. you just turn them till they release..
NOTE!!! you want to keep the old holders for the new bulbs to go into... simply just remove the old bulbs and chuck them as there useless...
fit new bulbs into holders and re fit..
I went futher and split the clocks... removed the clear plastic that is covering the dials.. and also them removed the black plastic part (both just clip off)
then i removed the needles... use a knife and get under it... be careful but put some force into a bit and it will slowly pop off..
do this for each off them and sit them to the side..
then remove the white/black dials.. dont worry they stick back on... turn over.. and scratch away with a screwdriver behind each number.. and also behind the petrol lines and temp lines and sympols..
refit... and put needles back on and refit the cover etc and plug it back in and job is a good one,..
(remember to check the bulbs work before screwing in etc.. if they dont.. then just remove and turn the holder 180 degrees and pop it back in and itll work)
Pics of my finished clocks..
http://
http://
http://
http://
http://
http://
