Hi people,
I was reading a post this morning about people wanting a detachable tow bar without a visible cut and I have one fitted to my Type-S.
The bar I have is a Witter detachable, part number HN55Q, purchased from Towequipe in Nuneaton. I had the single 13 pin electrical socket fitted too.
On the Type-S, the bumper cut is totally invisible, due to the rear splitter. The cut is on the underside of the splitter that is obviously mounted to the underside of the standard bumper. Looking at the standard bumper itself, it does have a cut that you would be able to see. Not a massive cut, but it would be seen.
The 13-pin electrical socket too has been mounted so that it swivels up behind the bumper, thus making everything completely invisible. Obviously the cut then had to be lengthened a bit more to allow space for the socket to tuck up behind, but the cut itself is still only around 15cm wide.
Hope this helps somebody, basically fit a Type-S splitter and you'll have no worries!
