dionysius said:
Hi
Need a new battery for my 2.4petol augo tourer.
The recommended fitment 075 battery is a woefully small 45Ah capacity nd I want something much heavier duty.
I notice the 2.2diesel cars have 096 battery listed which is much meatier.
But will it fit ? Dimensions are larger notably longer and taller.
Failing this do people know of a heavier battery that will fit or what the max dimensions one can go to are ?
There are a couple of battery codes that have same same width and length as 075 but are a bit taller eg 1.5cm - is there room for this extra height ?
Cheers in advance !
Although the battery in the 2.4 looks small and only has 45 Ah, it is rated to dish out 330 CCA for 30 seconds.
Ah gives you the amount of time that a small to moderate current can be maintained at 12V. So a 30 Ah battery would be able to maintain 30A for 1 hour or 15A for 2 hours.
CCA (Cold Cranking Amps) is the amount of current a battery can provide at 0 °F for 30 seconds while maintaining at least
1.2 volts per cell (
7.2 volts for a car battery).
There is no formula that relates Ah to CCA i.e. you cannot calculate the CCA from Ah, and vice versa. This is because CCA is related mainly to plate surface area in the battery, while Ah is related mainly to the amount of material in the plates. This means that two batteries with the same amount of plate material, one with a lot of thin plates and the other with a few thick ones, could easily have the same Ah rating but very different CCA.
Basically, unless you have some extra equipment in the car that is going to drain the battery faster than the alternator can charge it, there is no reason to change the battery. And if there is equipment that is going to drain the battery faster than the alternator can charge it, then the alternator should be uprated too.
See also the next reply below, because fitting a bigger battery could damage the starter motor.
Jon_G said:
Just put the two batteries in parallel using a heavy-duty cable to link the positive terminals together and connect the boot battery negative terminal to the car bodywork. This will then 'look' to the alternator like one big battery with the capacity of both added together. The alternator will be fine, it has built-in electronics to regulate its own output.
ouch, I did like your post #8 on its own, but now that you've added more detail, I'm beginning to get worried by this.
If there is equipment that is draining the battery faster than the alternator can charge it, then adding a bigger battery won't help because, surely, the alternator requires uprating as well ??
IMO Hamid needs to go about this properly. He needs to borrow or buy a "dc current clamp meter" and check the current being drawn from the battery with the amp playing, without the engine running, with everything else switched off. Whilst a dc current clamp may not show the variations in current with the bass content, it should indicate the average current draw, which is what you need to know in order to decide if the alternator requires uprating. If the average current draw is not large, then the only reason for requiring another battery, is simply to act as large capacitor to smooth out the voltage when the bass is drawing current.
tbh I am puzzled as to why the amp does not have large capacitors internally to achieve this, a good mains-powered amp should have a transformer/rectifier/capacitor setup big enough for this issue, and I don't see why a car amp shouldn't have this too.
If you do decide to fit another battery for the amp, IMO you should cable the amp directly to that battery, and fit a diode with large current-rating, plus fuse, from the alternator to that battery. That way, the battery for the amp is electrically isolated from providing power to the starter motor during starting.
You should not uprate the total CCA to the starter, because it could damage the starter motor with too high a voltage during the CCA period.
But, as I pointed out above, if the
additional load that the amp takes
is too big, then the alternator would need uprating too.
edt: see also this post for the starter motor details in the 2.4
http://typeaccord.co.uk/forum/topic/18360-has-my-alternator-seized-or-my-engine/?p=200909
