The only way to express the meaning of the word above.
When I bought my car the left side was higher then the right, the rear left shocker was leaking so I had it replaced, car sat better for a while, the front end was atleast 3m down from one side, I changed that shocker and it sat even lower, baffled by this I swapped the front two shockers around, it was much better (for a few minutes anyway) got home from the garage and checked it again - the left side is now EVEN higher than the before and the right is completley down, almost touching the inside of the wing
I cant figure out what it is??
My car is now even worse than when I started and im £150 out of pocket !
