Nathylad
Ok, after changing my discs and pads last week I had a few request for pics.
Unfortunatley I didn't take any pics at the time but I thought I would take the drivers side brake apart today as I had a spare two hours and take some pics as I went along.
I didn't keep the old discs and pads so no pics of those but you can hopefully see what I did with the pics and description below.
Ok, first thing first, loosen the wheel nuts and jack the car up.
Once on an axle stand I tend to keep the wheel under the car.
You'll end up with this....
Now to remove the caliper you need to undo the two 12mm bolts going into the pad carrier:
The bolt on the top:
And the bolt on the bottom:
Now pull the caliper out and cable tie it up. Don't leave it hang by the brake hose!
Now use an impact driver to remove the two screws holding the disc to the hub. Don't try using anything but an impact driver, take it from someone who tried and failed!
Once removed your hub will look like this:
Now get a wire brush and brush all the rusty build up off the hub so that the new disc has a nice flat surface to sit on.
Make sure you spray the new disc with brake cleaner and attach it to the hub with the two screws you removed.
Now for the caliper. Get your rewind tool (some people can push the piston back in) to push the piston back far enough to accomodate the wider width of the new pads and disc.
While the rewind tool was in the caliper, I decided that the brake pad holder and the clips needed a little clean. You can use a wire brush, or a dremmel. I find that the wire brush removes some of the rust but the dremmel works best (I'll be painting my calipers soon so i'll write something more detailed then)
Now put the clips back into the brake pad holder and then put your new pads onto that.
Bolt the holder back onto the hub using the 17mm bolts you removed earlier.
Now remove the rewind tool from the caliper, cut the cable tie and bolt the caliper back onto the pad holder with the 12mm bolts.
I find that now is the point you stand back and admire your handy work!
Now put the wheel back on, torque back up and lower the car back down.
Repeat on the other wheel and you're done!
I've described this as best I can but please feel free to add in any bits I may have missed out. I don't think there is much missed though.
