wahabishtiaq said:
Yes, yesterday I did it. Just needed two persons...
- Lifted front pass. side with jack to be able easier operate underneath.
- Disconnected one of generator cables (green socket, rubber cap), unscrewed 10mm bolt held plastic cable cover (under EGR) to engine. Moved plastic cover with cables as much as possible away from engine
- Using grinder made face of 12mm socket flat (removed rounding) to make sure socket going deeper on the bolt head. (probably this is not "must" but I did it)
- Next to socket fit cardan, then two extension bars from the socket set.
- Fit socket to the nut, found way extensions to go down under car. (cardan allows to find way down)
- One person held socket and all extensions by fingers over the nut properly.
- Other person underneath the car trying to unscrew nuts. Initially it needs quite big force until hear crack, then can unscrew the nuts by fingers.
After EGR cleaned, I fitted new bolts+washers (because I had them). Before that I put some graphite grease for easier future unscrewing.
