(sorry for the dirty accel pedal :cry: )
you will need:
10mm socket
12mm socket
ratchet
3.2mm drill bit
rivet gun
optional: Dremel type handtool with the hole cutting tool! you'll probably need this to adjust the holes that you drill!
you'll need to drill 3 holes in each of the brake and clutch pedals to fit these.
The foot rest just unclips off....I say JUSt but you know it's always a bit harder lol
The accelerator pedal has 4 bolts to be removed. you unclip the accel cable by pushing the cable off the holder... outwards from behind, then you have to try to pull the cable ***embly off the accel pedal bolts and slide it upwards to remove.
you have to have patients for this...especially the drilling! get GODD drill bits and use a 2mm drill first to drill a pilot hole first........the steel is DAMN hard!
ok here goes. (PICS AT BOTTOM so please read :wink: )
I test drove a standard 2.4 Type-S before i bought my car so all my opinions are relative to that.
