Mr CL7
Tools needed
Flat head slim screw driver
Star screw driver to remove two screws from fascia
Wire cutters maybe required depending on length of bulb wires
Feel for two screws at the bottom of the large fascia which has the coin pocket. One left side, one right. Once they're out you can gently pull the whole section away.
Make sure to disconnect the plugs for the fog light and headlight switch. Mine is the far right in the pic below
Pop out this window by pushing from the back gently
Push out the switch from the back of the window gently
Switch in hand
Here we see the side of the switch. The brown circle part is the back of the bulb holder with the wires attached as you can see
I have removed the adjuster switch from the front by using a slim flat head screw driver to prize it off
Close up of the bulb. You can just about see it inside
Circuit board removed from switch. It comes off easily enough
Circuit board
Back of circuit showing brown circle bulb bottom
Front of circuit showing bulb
Switch in hand
Circuit board
