Haven't got pics, search the forum.
Screw underneath the small rubber mat in the pull handle, and also prise off the plastic off the pull handle, you see a small notch where you can get something in to pry it off which will reveal 2 more screws.
Then from the bottom corner start popping the door card off and work around, unplug the couplers for the switch and puddle light and also the cable for the handle.
That;s from memory anyway.
Remember to put the cable back on and lock in the retainer tab otherwise your door won't open from inside.
