Blue Guru
JDM Oz
http://www.youtube.com/watch?v=nH_xq_ZwLuw
Awesome job bro, you done really well on this one
Love the Japanese-random-mixing-English-words-with-Japanese-because-it-sounds-cool intro.... not sure how useful turning a lights off would be though
The guy in the ek9 is a pro racer, he used a racing technique they've called "the disappearing line" to overtake the 86. Takumi in the 86 is confused as to how he was passed so easily. So as he's backed into a corner he adapts and decides to make the pro racer think he's disappeared by turning his lights off and taking him on the inside with late braking. This anime is amazing as all the technical info in it is 100% correct as it was overseen by the drift king keichi tsuchiya
Hi, I'm not sure about the canbus issues but this should be a straight forward job. You can use this harness (locally available- not sure): http://item.mobileweb.ebay.com/viewitem?itemId=360472892077&index=5&nav=SEARCH&nid=66459286732
...or you will need a double din fascia adapter: http://www.lingshondaparts.com/honda_car_parts_selection_pfk.php?block_01=17SEA01&block_02=08B0601&block_03=2771
Once fitted, you will only lose steering radio control; std radio will remain functional incl. display but with NO volume.
I have a single din set up, hope this helps.
At the top, where the vents are??? Custom job that, can be done too. Mind you your summers will be proper bakingYeah see thats the bottom positioned double din, loads of people have done that. I want to put mine up the top!
You will still/may need to cut & join- wires are colour coded. Not sure about powered antenna, but cc display is fully functional. Adapter plate: http://www.dynamicsounds.co.uk/autoleads-fp1504-honda-accord-sport-executive-facia-panel-adaptor-p-2470.htmlMany thanks B) . So from you are saying, if I order that lead up, I don't need to cut any of the existing loom? And it just all plugs together. Keeping the powered antenna, also climate control display? Anyone recommend a single din Adaptor plate that won't need any fabrication?
Couldn't find the double din fascia for 7th gen. Only single din if you choose that route: http://shop.mobileweb.ebay.com/searchresults?cmd=SREF&pg=1&kw=Accord+metra+kit&fads=1&sort=BestMatchYeah if you can do that mate, that'll be great! I can see why people put them at the bottom its so much easier.
hey pete sorry have been away for a while and didnt notice inbox was full,if you need any thing give me a shout(inbox now empty )Have ordered the harness and adaptor plate today. Just deciding what head unit to go for, but thinking of the Parrot Asteroid and do without DAB?
