Hi there
new to here so if anyone can help please
i have a 05 Honda Accord EX 2.4 saloon, the other day the managment light came on dash so took it to local garage to get put on their machine/computer to see what came up, the code that came up is DTC P2A00 ( 02 sensor circuit range/performance ) (bank 1 sensor 1) now i am no mechanic nor have ever tried to be so im hoping you guys can help me out with a list of could be problems for this code that i should have checked, also just ot put you guys in the picture, a day before this light came on my friend who is a mechanic had changed front passenger upper whishbone and also had taken the strutt off the same side as been getting a weird squeaking noise getting louder for a few months from that side and since in the last couple of months i have had anti roll link and lower wishbone arm all replaced we thought the noise may have been coming from strutt or strutt mounting so he took strutt off and checked the mounting kit ect all seemed fine but whilst taken off the strutt the abs,vsa sensor cable was corroded at rubber where it sits in bracket and broken, so just as a quick fix and only thing lying around we used block connector which worked good enough to take abs and vsa lights off dash again, this sensor cable is away to get fixed asap as there was two codes coming up for that sensor which are DTC13-1 open circuit or short circuit and also DTC 61-1 low battery voltage so we are sure that once that sensor is fixed theses codes will be gone, anyway ends up after stripping all the strutt ect down the squeaking was coming from the auto headlight adjustment arm/sensor which is located beside passenger front wheel and connects to bottom of strutt with a small arm/link, as the squeaking was driving me mad and it was so loud that it turned heads when driving around town, (sounded like jumping up and down on an old bed mattress) we decided to disconnect the arm / link from bottom of strutt and cable tie it out the way until i could get the item replaced and also peace from that horrible noise, all was great until next day and thats when the engine light appeared on the dash, i dont suppose there would be any connection between what we had done and the engine light coming on (DTC P2A00) would there, i take it that this was just a coincidence or is there a chance that with having these other things done something has caused this code to happen, im real sorry about this being so long but i thought it better if i explain everything that happened just before the engine light came on so you guys have a picture of what may have happened,
many thanks for those of you taking the time for reading all of this and hope to hear from you soon
all the best Millar
all the best Millar
