Engine shutdown rattle after EGR/DPF delete – normal behaviour?
Júlio Rocha
Portugal
8th Gen. I-DTEC
Hi everyone,
I own an Accord 2.2 i-DTEC (N22B1) which has recently had a full EGR and DPF delete (both physical and electronic). Since these modifications, I’ve noticed a specific behavior that I’d like to run by you.
When I turn the engine off, there’s a very brief metallic rattle/chatter (lasting about 1 second) right at the moment the engine stops. It’s not violent or continuous, just a quick sound as it shuts down.
Key points to note:
  • No vibrations or hunting at idle.
  • No vibrations or weird noises while driving.
  • The clutch bite is perfect and there’s no slipping.
  • No clunking when pulling away or changing gears.
  • Crucially: If I depress the clutch pedal while turning the engine off, the noise almost completely disappears.
  • The car runs very smoothly, and injector values are all within factory specs.
My main question is: could this rattle simply be a result of the engine no longer performing a "soft shutdown"? I know many diesels use the throttle body/anti-shudder valve in conjunction with the EGR for a smoother stop, and I wonder if the delete makes the shutdown more abrupt.
I’d love to hear from anyone who has:
  1. A deleted EGR/DPF on this engine.
  2. General experience with the N22B unit.
Is this slight rattle considered "normal" under these conditions, or should I be worried about the Dual Mass Flywheel (DMF), even though there are no other typical DMF symptoms?
Thanks in advance for your help!
Note: translate PT-EN with IA :D
Sounds like your flywheel is a little out of balance, pretty common and nothing to really worry about until it develops into a knocking at idle.
Shortly I will post a small video so you can see how it shuts off, with sound. Thank you F6HAD, always helping people. Happy New Year to you and your family! :)
Hello! Here is the video. I had just returned from a short trip, meaning the engine was hot. I'm not sure if the on and off noise is normal. Can you confirm? Thank you.
