Hello, does anyone have tips or a DIY for flushing the automatic gearbox? My car follows the maintenance schedule with a Honda dealer, but i don't know if they flush the entire system or just pour some out and fill it up again.
How much did they charge you?old cruiser said:Had mine recently done by the dealer and they confirmed it was flushed through, whether this is to be believed or not is another thing!! I think they are supposed to drain the fluid, then fill back up, run the car for a few miles and repeat the procedure at least twice, so if your dealer is trust worthy then you should be ok , otherwise you could do it yourself but make sure you use the correct Honda fluid as the gearboxes are sensitive to using the proper stuff.
Cheers Pete
