Front Sway Bar Bushings
Simkin
Norway
2009 Accord
Do i need to loosen the sub frame to change the front sway bar bushings? 2009 Tourer DTEC.
Is 2009 7th Gen? If so, then yes. If it's 8th gen, I imagine you still do as they're basically the same chassis platform with an updated body shape.
Changed them yesterday. Have access to a lifter so changing them without lowering the sub frame went fine. Little tight space at the bolt in the back but could get them in and out without any problems.
Any special tools to get that rear bolt out?
