fuel filter bleed-is it necessary between changes?
bikes4two
Havant
Accord Tourer 2006
'06' Facelift Diesel tourer
QUESTION RE FUEL FILTER BLEED
- The Honda handbook says change the filter every 25k miles with a 9water) bleed in between, i.e. at the 12.5k point.
- The denso filter holder on the facelift has a water sensor does it not?
- If the water sensor is not warning me of water present, should I just be leaving the fuel filter alone and just changing every 25k miles, or is it not as simple as that?
Thanks in advance
here is DIY http://typeaccord.co.uk/forum/topic/871-diy-i-ctdi-fuel-filter-drain-and-bleed-procedure/ but its for pre-facelift models, if someone know how it looks in facelift models don't hesitate to share your knowledge :D
Also agree its good practise to do a FF bleed in between the 24 month change.
Having said that, I changed mine twice over the years and bled in between and never had any water......
