luke w
Been having slight running issues for a while now. The slight issue seems to match issues regarding either the EGR valve or fuel filter, ie, bit flat lower down the rev range, little bit of hesitation. Now the EGR valve has been deleted when it was remapped and has been blanked off and the fuel filter was changed not that long ago with a genuine Bosch filter. I've cleaned and replaced a few things but there's been no difference so thought I'd investigate the fuel filter to be on the safe side and upon giving the priming bulb a quick squeeze I could easily squeeze it to the point I could touch my thumb and fore finger. After a few squeezes it hardened (but never got fully hard, always about 5mm of give) but if then left for 5 minutes or so it was back to being easy to squeeze. I loosened the bleed bolt at the top of the filter and squeezed the bulb until firstly a few air bubbles came out then just diesel, nipped it back up a gave the bulb a few squeezes (at least 30 odd) again until as hard as before (still a bit of give). But, it's still going really easy to squeeze after a few minutes.
Now reading up on various threads on here, I get the impression that the bulb should be hard straight from the off and not need a few squeezes to become hard. So, any idea why I'm getting this problem? There are no fuel leaks so as far as I can see (all the hoses are dry and no puddles under the car or drips anywhere.
