Hi everyone, just bought a running 7th Gen 2.4 AT accord, vehicle has transmission issue specially shifting from 1st to 2nd with a hard jerk.
after reading through and research had tried all possible means to maintain and keep with same transmission instead of replacing with a junk yard one,
Vehicle doesn't have any DTC in scanning tool, further at first had taken and inspected both the solenoids and had clean the tubes screen with fresh O-rings, and seals & ATF all original from dealership.
after the procedure had tested and yielded the same result further after a week had used Luca's Slip transmission fluid. but still in same state of discomfort.
I heard about testing the PCV, dose anyone has any clue if this would be another attempt to be looked after?
further some stated it could be Oxygen Sensors? as the vehicle is scanned several times and there are no fault code.
