Gearbox oil change for 07 cdti - Type and quantity please
antdad
Heathrow
Tourer i-cdti 07
Just had the under tray off (first time by the looks of it) because I have an oil leak. Still not absolutely sure of its origins but the gearbox sump nut and surround is fairly wet but then so is most of the front sub-frame. The gearbox isn't as precise as I thought it would be even though it's done 125k would a lack of oil cause the vagueness and as above might as well change it out but haven't got hold of a manual yet. TIA
from the thread you quoted:
"Check the hole where the inspection bolt had been removed, it is unlikely any fluid will be escaping just yet. Continue with your third litre of fluid (manual states 2.2 litres for fluid change), at the point where fluid starts to spill from the inspection hole, the gearbox is filled. You can now reinstall the bolt removed from the inspection hole."
The car should be level (i.e. not jacked up) when filling to ensure you get the right amount in.
Thanks, hadn't read the thread fully, trouble is my drive is on a fairly severe slope and so is my road so I may just have to measure it out.
Can't you jack jour car up to get it level ?
Cliffordski said:
The manual says 2.2L but in the real world it takes 2.5L to make it overflow.
agreed it
shows 1.9 - 2.2l in wow software
