[Guide] How to replace the factory sat nav with an aftermarket head unit
btjtaylor
Active Member
Accord CU2 Manual
I will stop short of producing a step-by-step guide on how to replace the head unit because there are a lot of variables and there will still be some work required to connect everything exactly as required, but I hope this information is useful to anyone attempting the same
There are loads of other videos/posts about taking the dashboard apart so I won't repeat that here
The parts I purchased:
Dash fascia adaptor:
I used AVC 381130-11
https://shop.acvgmbh.de/index.php?s...e(detail,flextor)&_edit=3222&search=381130-11
InCarTec 50-897 and other similar models available
FM Aerial harness adaptor:
InCarTec 21-118
https://incartec.co.uk/product/Nissan-06--Aerial-cable-adapter-to-DIN-radio
Adaptor for reverse camera (requires modification as the connector doesn't fit an accord):
https://www.aliexpress.com/item/1005004625021947.html
or (doesn't require modification
https://mobilemaxcaraudio.com/produ...-tsx-factory-backup-camera-retention-harness/
Steering wheel controls adaptor + harness adaptor:
InCarTec 29-679
https://incartec.co.uk/product/Hond...-Jazz-steering-wheel-control-interface-29-679
Climate control retention cable:
https://mobilemaxcaraudio.com/produ...rol-conversion-harness-navigation-to-non-nav/
ELS amplifier retention interface:
https://mobilemaxcaraudio.com/produ...cura-els-audio-amplifier-retention-interface/
Without this the factory amp is stuck at a low volume level
Arm rest USB retention cable:
InCarTec 24-251
https://incartec.co.uk/product/Honda-Mitsubishi-USB-Retention-harness-cable-24-251
or available more cheaply from Aliexpress e.g.
https://www.aliexpress.com/item/1005002503470909.html
Display screen from base model car:
Should be loads on ebay but if you are struggling search for "D099T"
Dash storage cubby from base model car:
Again should be plenty on ebay. If you can find someone breaking a base model car, you could ask them to send you the display screen, dash cubby and the wiring/connector from the display screen to splice it in yourself
Reverse light wiring
You can take a reverse light feed from the wiring in the driver's fusebox (on the right of the accelerator pedal)
The light blue wire in this area connector is the 12v feed for the reverse light, as per the wiring diagram:
Main harness wiring
This connector removed from the "Audio Unit" (CD changer) is where most of the stereo connections are made:
Here is the pinout of this connector:
The ELS module from Acura Audio Garage came with the Honda connector on so I didn't need to do too much to this.
The steering wheel control module connects to pins 5 and 16 of the Audio connector "A" (the connector above) as per this diagram
There is also a wire that connects to the connector removed from the bluetooth module in the passenger footwell (you can get rid of that as its no longer needed) which allows the answer/end call buttons to work
I had to splice these pins in to the harness provided with the ELS box as that one came delivered with wiring for another steering wheel control setup.
The factory amplifier in the boot receives a line-level signal so you need some RCA connectors on the harness (Pins A18,A19,A22,A23, as per above), to send the signal from the pre-out connectors on your head unit
The end result will look something like this (this was a previous attempt that I hacked up!)
Factory amplifier control
The biggest problem with this task that I found is that the volume level was not adjustable. The factory amplifier in the boot is controlled digitally so without the factory head unit you are stuck with it at a low volume level. In the wiring there is a mention of "ELS" data which seems to be some kind of proprietary amplifier interface. The ELS interface wiring from Acura Audio Garage (linked above) was the only solution I found to this problem, albeit an expensive one :(
It connects to this plug that is removed from the factory audio unit
Here is the pinout I found in the service manual and how the adaptor is wired up but I didn't find any information online about how it works:
I mounted the volume control on the trim here (there is a space behind to feed the wire):
Reverse camera wiring
Once you remove the top display screen you will see this connector:
This connector contains the wires that connect to the reverse camera. I purhcased the adaptor noted above and the connector was wrong so I had to chop it off and wire it up like this:
Once the reverse light feed is connected (as per above) the head unit will know when the car is in reverse, the camera will be powered from the reverse feed and the reverse camera image is displayed
I wired this up using In-sure connectors (I don't trust my soldering, especially in a tight space) and ran the cables back down behind the dash to the head unit to make the connections:
Climate control display
When you remove the factory head unit you lose the ability to see the climate control information
In order to remedy this you can install the display screen from the base model, but it has a different connector.
You can use the pre-made adaptor and run it up behind the dash to the display screen area:
I did figure out the wiring from the diagrams in HDS but I didn';t actually test making my own adaptor:
USB port in arm rest
This is fairly straightforward - the adaptor cable (mentioned int he first post) above connects to the plug on arm rest like this and gives you a standard USB connection you can plug into your head unit. Once this is done the arm rest USB works as normal
I gave this area a thorough clean afterwards for obvious reasons !
FM Antenna
This connector behind the dash is used for the FM aerial - just connect the adaptor (it needs a power feed too but you can take that from your head unit's wiring, typically) and away you go
And finally, here is the finished article!
One of those jobs where about half way through you regret your decisions but you're in too deep... the wonders of modern car infotainment systems!
It was a good sense of accomplishment to get everything working but from a value for money standpoint it was a massive fail
I think for most people a USB-powered AUX Bluetooth dongle and a phone holder will suffice, at probably about 50 times less the price..
Yeah, i have one of those plug in AUX cables, cost me about £15 and took about 10 mins to install
still, yours looks cool. well done ;)
I must be the only person who actually likes the stock infotainment system lol. My only gripe with it is the stock head unit turning down bass at high volume which is pretty damn annoying if you listen to rock or metal but that can be fixed relatively easily with a custom EQ preset on your phone.
Great write up, congrats on pulling it off.
Hah thanks - it's a good sounding system which is why I was keen to keep the amp rather than rip it out but I wanted to have a more up to date Sat nav which I like to have especially if you end up in a place with no signal, and I missed the DAB radio from my last car. I don't use it a huge amount but it's nice to stick on when you can't be bothered to find something on your phone, for short journeys etc.
The bass reduction you mentioned - I've not noticed that to be honest - hard to say if it's the head unit or the DSP in the amp doing that - unfortunately I've lost access to the tone/balance/fader controls of the factory system now although I can obviously do an EQ in my head unit instead. I don't think I've ever needed to adjust balance or fader on a car audio system other than troubleshooting blown speakers once but I can see someone might want to if they have kids in the back, maybe (grasping at straws)
It sounds good to me thats the main thing
Thanks for the brilliant guide, really appreciated. One day I hope I'll get round to emulating this.
Wow this is amazing, been wanting to do this for ages just didn’t know where to start. Like you said expensive but think it’s definitely worth while. Just 2 things, how did you mount the volume button? Also the first bit, taking a feed for the reverse light confused me a bit I got everything else just don’t get what you mean by that?
No worries, I can try to help:
Reverse wire:
Most head units have a wire as part of the harness that should be connected to the reverse light +12v signal of the car. Typically this is used when you are connecting a reverse camera, so that the car (a) knows when the car is in reverse so it can display the camera feed on the head unit screen and (b) can power the camera only when it's needed
There's a video here that explain the generic principal
I believe some head units also use this for the sat-nav to know when the vehicle is travelling backwards in an attempt to avoid the arrow on screen spinning while it tries to figure out where you're going
Technically you don't need to connect it but as all of the cars that have sat nav also have a reverse camera (as far as I am aware anyway) , it's necessary to use it
Volume knob mounting:
I don't have a good photo of that but I just drilled a hole in the pictured trim piece and mounted the button on it (it has a screw which attaches). I did it here so if I wanted to undo it I could replace the trim piece with one from a breakers. In hindsight i'd probably actually put it inside the centre console cubby that you gain, it's OK to be hidden as you don't need to adjust it a lot, its pretty much set and forget (think of it as a gain control for the amp rather than a volume control). Day to day I use the steering wheel buttons to control the volume.
Thank you for getting back. I am going to attempt at some point. Got to replace my rear parking sensors first, always something to do
Is there a way to keep the original stereo so you keep the air con display screen and just get a big screen to go on top to replace the old navi screen?
It should be possible but you'd likely have to do quite a bit of custom wiring for it
There are some Chinese android units on AliExpress I believe that fit where the top nav screen is
The issue you'd probably run into is that you need to unplug connectors from the stock head unit in order to connect the android unit and this would probably result in the stock HU being turned off. But if you splice into the wires you need and reconnect the plugs it should work. In fact, it's probably best to feed the audio from the new head unit into the wires that feed the aux input for the factory one and leave it in the aux mode the whole time. That way you could avoid buying the expensive ELS amp interface.
Could be a good budget option if someone can figure it out. Reverse camera fed to an android unit in the top screen, feeding audio via the aux input of the factory system. The only real disadvantage I can think of is that you don't get the storage cubby instead of the CD changed which I really enjoy having!
Yeah and I’m probably not the man to figure it out either haha. Could you not just rip out the cd player anyways to replace with storage cubby?
I think its necessary to leave it in as the amplifier etc actually connects to the CD changer unit, not the section where the buttons are
Yeah believe you’re right. I actually found one on Ali express that is compatible with factory navi. Like you said, it will feed through the aux line. It costs about the same price to do if your way and think your way makes the car looks cleaner so gonna go with that. Thank you
