I had the gearbox oil and clutch fluid changed because 1st gear was sometimes a struggle to coax in. Well since the fluid changes, when I drive the car for the first few minutes, the first and second gears are tough to change, it's almost as if the lever has seized and requires a bit of muscle to change. After a few minutes the changes become much easier. Any ideas?
