tbh Alan, your description flies in the face of basic mechanical gearing. Firstly, a diesel's starter motor has a much bigger torque than a petrol engine (which is why diesel engines have bigger batteries, to provide the current, which the starter motor requires to provide its torque). When the starter rotates, its pinion is engaged on the ring of the flywheel, which gives a massive increase of torque onto the crankshaft. It is the rotation of the crankshaft that causes the pistons to move, so I fail to see how you can say that the torque available at the pulley end is less. If you apply torque to one end of a shaft, you cannot lose the torque at the other end of the shaft unless the shaft twists. So the torque provided by the gearing of the pinion onto the flywheel will absolutely and always be available at the pulley end while the current is being drawn into the starter motor. The only thing that can reduce that torque is to reduce the voltage (and hence the current available) across the starter motor (or to disengage the pinion from the ring).H Peasource said:Great news, Colin. Now go and buy yourself some hair restorer to celebrate.
When I first saw this a couple of years ago I too couldn't believe it and it niggled away in the back of my mind for quite a while until the penny finally dropped.
We all know that it takes a fair amount of torque to turn over a piston engine and that diesels are worse in this respect than petrols because of their higher compression ratio. That torque is applied at the flywheel end of the crankshaft and most of it is absorbed in overcoming the friction and pumping losses. The amount of torque available at the other end of the crankshaft (the excess torque if you like) is much smaller. With that in mind it becomes much easier to understand how a siezed alternator can do this.
The old trick of using the starter motor to undo the crankshaft pulley bolt could almost have been designed to mislead us into thinking there's a lot of torque available at that end of the crankshaft. In reality there are two factors which explain how this trick works. The first is that much of its success is due not to the torque of the crankshaft but to the shock loading applied to the bolt. It's basically the same as the way an impact wrench manages to use a relatively low torque motor to undo tight bolts. The second is that, when doing this, there's inevitably some rotation of the crankshaft before the breaker bar (or whatever you're using) smacks into something solid. That's important because there is a big difference between the static friction, when the engine is stationary, and the kinectic friction when the engine starts to rotate. Indeed the static friction will be over twice the kinetic friction. The combined effect of both these factors is to produce a shock loading big enough to shift the crankshaft pulley bolt or snap the crankshaft if you're really unlucky!
Alan
I think it is important that we get this right, as otherwise "maybe the alternator is seized" will become a never ending piece of advice dished out to people whose engines are not rotating.H Peasource said:I won't get into a slanging match Brian. Suffice it to say that I do understand ¨basic mechanical engineering¨, indeed I have a degree in the subject and am a member of the relevant professional bodies.
A torque is no more than a force and, like any force, it can be absorbed - in this case by the internal engine friction and, once the engine is turning, by the pumping losses too.
Perhaps we should just agree to disagree.
Alan
As I've put above, you're confusing the rpm for starting the engine with the static torque. The rpm for starting is around 600rpm (10 revs per second), at which point the starter motor is providing maximum power, which is not the same as its maximum torque (at zero or very low speed). So if a starter motor cannot rotate a crankshaft at all, then it implies that either the engine is locked solidly (seized) or that the starter motor is not getting enough current (battery or cable issue).TheHole said:I for one am not supprised a seized alternator stopped the engine turning.
I presume the aux belt is the old longer one? With the belt comming off the compressor down to the alternator then making an almost 180degree turn up to the idler pulley... There is alot of force on the alternator (enough force as many of us know to kill the bearings in the alternator)
To settle the argument above.
The starter motor is able to provide a huge amount of torque to get the engine turning... But with all electrical motors, torque drops off quickly when the motor starts spinning.
The initial current rush in to the starter can turn the engine over its compression points.
Once the engine has started to rotate the torque from the starter motor is turned in to kinetic energy to turn the crank and therefore the internals and auxiliaries.
As this happens torque has dropped off in the starter motor, but the now given kinetic enegry of the engine internals help alleviate this issue of loss in torque in the starter motor.
Plus add in to the factor that once the engine has done less that 1/4 of a rotation, fuel is already being injected in to the next corresponding bore to attempt the start of the engine using combustion.
With an issue here where the alternator was seized, the start motor was not able to overcome the extra resistive force of the stuck belt and was not able to start.
A more concise answer than my one Jon, I would probably not have posted had I seen it, but I was too busy typing those longer descriptions at the time (and no point me editing out what I have put time into posting IMO)Jon_G said:But the engine wasn't turning, so the series-wound starter motor would have carried on delivering the maximum possible torque and there would have been no pumping losses as the engine wasn't turning.
Nevertheless, the seized alternator DID prevent this engine from turning. So I suggest that there was a combination of faults, with a discharged/poor condition battery being a contributory factor.
freddofrog said:I think it is important that we get this right, as otherwise "maybe the alternator is seized" will become a never ending piece of advice dished out to people whose engines are not rotating.
I don't want to be rude, I honestly don't, but if you are an IMechE (which you imply) then I would have expected a better description than you gave in your previous post. You are also not really understanding pumping losses properly. If the pistons move slowly, then the pumping losses are very small. On that basis, it is possible to rotate most engines slowly by hand, or to put the car into gear and push the car slowly. The starter motor provides most power when the engine is rotating at around 600 rpm (10 revs per second), but its static torque (and even slow rotational torque) is immense. I would expect a belt to make it very difficult, if not impossible, for the starter to provide sufficient rpm to start the engine, but not to stop the crankshaft from rotating totally. If the crankshaft does not rotate at all, then either the engine is seized, or there is not enough current getting into the started motor. I would bet my house on this.
Both (and anyone else) .....I do not and will not "agree to disagree" on a subject like this. In economics and politics that is a well-used statement, but in engineering that statement cannot be used, and IMO it is very important to get things stated properly in engineering topics.
It is quite possible that the "recovery man" simply went down the recovery route because he quickly realised that recovery was the easiest option for him at that time, he may even have seen/heard the engine rotating very slowly with his battery pack attached and decided that it was not up to him to remove the belt to check (which he could have done if he wanted to give a 100% diagnosis).
TheHole said:You glanced over my ****ysis somewhat and its difficult on a phone to get a concise reason across.
which is mainly about the starter getting the engine to run up to starting speed i.e. running up to a point where "pumping losses" start to become large, but my reply to you was that this is not the case when the starter motor is initially rotatingTheHole said:The starter motor is able to provide a huge amount of torque to get the engine turning... But with all electrical motors, torque drops off quickly when the motor starts spinning.
TheHole said:I would like to see someone go over compression point on the accord by hand though... Its not that easy with out a tool...
TheHole said:The gearing on the starter / flywheel is designed thus the max speed is IIRC (and im happy to be corrected) is about 100 rpm over starting rpm of the engine.
This allowd some leway when starting and provides for a battery volt drop etc.
TheHole said:Its all in the gearing of the pully system... Again going back to my original post of me not being supprised about the lack of torque to overcome a seized bearing in the alternator
aye, you have to make sure the missus hasn't left the windscreen wipers on, and you have to shut the door too ......joke about Skoda from the 70's .....rhinogolf said:So there's a lot more to starting the car then turning the key
Hmmm, I just tried to have a look but it seems my Honda service manual won't run under Google Chrome (a pop-up is telling me to run I.E.)... I still have a laptop running I.E., but that can't post on TA!!! Will obviously have to sort this out.freddofrog said:I decided to put some numbers to what we've been talking about, and I've gleaned the following data from the Honda CD for the 7th-gen pre-facelift 2.4 Accord Tourer.
There are 3 different makes of starter motor, of various kW ratings. I've constructed this table from the cranking tests in the "Starter Circuit Troubleshooting" section.
.....Denso 1.0kW >8.0V <200A
.....Denso 1.1kW >8.7V <230A
...Mitsuba 1.2kW >8.5V <350A
...Mitsuba 1.6kW >8.5V <380A
Mitsubishi 1.7kW >7.7V <400A
Before I continue, can anyone (e.g. Jon) check on the Honda CD for the 7th-gen pre-facelift 2.2 Accord Tourer, to see if the info is the same ???
Also, the battery in the 2.4 is 45 Ah with CCA of 330 Amps, what are the figures for the battery in the 2.2 ???
CCA of 780 Amps is huge , 77 Ah is a lot too.Jon_G said:Hmmm, I just tried to have a look but it seems my Honda service manual won't run under Google Chrome (a pop-up is telling me to run I.E.)... I still have a laptop running I.E., but that can't post on TA!!! Will obviously have to sort this out.
My 'genuine Honda' (actually made by Johnson, formally Delphi's battery concern) has a CCA rating of 780A and a capacity of 77Ah.
:lol: :lol: :lol:Jon_G said:Thank you Brian.... you are clearly more knowledgable about computers that you are about feeding a cat!
