accord20se
Hi everyone,
Used to be an active member on the old thaoc page but turns out I've never posted on here.
Got a problem on my dads runabout (1999 'V' Accord 1.8) and was wondering if anyone could shed some light on a solution.
One of the headlight bulbs went out so when he went to change it he noticed it was really dull on the drivers side, so proceeded to try another bulb. After 3 attempts and still nothing we took a bulb from my Accord and it was the same so there must be a fault elsewhere.
The symptoms are when dipped beam is on the drivers side is dull and when you switch on high beam the passenger side lights up normally but the drivers headlight practically switches off with all bulbs barely lighting up. The other strange thing is the blue main beam light on the dash doesn't come on at all.
Any help would be much appreciated before I start stripping down the electrics.
