Hi guys
i've got a 2007 accord diesel tourer. The problem is with the air temperature coming out of the drivers side vents. When the air con is on and set to its lowest temperature the air coming out the drivers vents is warmer than the passengers side. If you set the passenger side temp to 18/19 its around the same temperature then. Its most noticeable out of the centre face vents either side of the hazard lights switch. It does not matter if you use the "dual" button or not. Ive had a look through the forum for this but cant see anything. So is this a fault or is it a characteristic of the car. As anyone else come across this??
