Has anyone had any problems repairing or replacing their brake master cylinder?
I have a 2003 2.4 Tourer which has a 13/16" BOSCH brake master cylinder honda part no 46101-SDD-E01.
I have started getting air in the front right & rear left brake lines with the occasional brake pedal having to be pumped to engage the brakes. I have not lost any brake fluid from anywhere so suspected the brake master cylinder letting by as the pedal also drops slightly if stationary with the foot brake on.
Now the problem:
- The brake master cylinder is no longer available from Honda
- There is no listing for an aftermarket part with any of the parts suppliers I have tried
- Honda can order me a replacement piston set at £160 and it should be available sometime in June!
- Bought a seal replacement kit from Biggred, listed for the car and it has the wrong seals in it so they gave me a refund.
I now have a car sitting on the drive with no brakes and unable to replace or repair the master cylinder. Next step is the breakers but the chance of getting anything decent is probably remote as mine has just gone after 20 years and the bore is in great condition.
Any pointers in the direction of a solution would be greatly appreciated.
Last option is to cobble together Bosch seals of the same size and wait for Honda to get a piston set in.
Now the problem:
