MattUK
Hi Guys
Wondering if any of you might have come across this one before and whether you think that the advice that we are getting from our local dealer sounds right?
We've had a problem with the battery going flat for a while now; have replaced it with a Bosch unit and thankfully we have a powerpack thing for starting if necessary, just as well as the new battery didn't fix things. Took it into our local Honda today & asked them run an electrical test to see what might be draining the battery (£50 to run the test!) - was told that we would need a new HFT unit at £1,749.41 + 1/2 hour labour to fit @ £54. Apparently this is not an uncommon problem, they had the same thing a couple of weeks ago with another car.
I asked them to let me know exactly what was wrong with the unit and they came back with "We don’t actually know what the fault with the HFT is, they are sealed units so we're unable to get into them to the physically see the issue. We do know that they cause a dark current draw which is what is causing the battery to drain". They have recommended that because of the cost, they just leave the unit disconnected and have said that this shouldn't affect anyting else (ie. satnav, audio etc should continue to work as normal).
I'm really keen to get your take on whether this is a reasonable response from the dealer - at the end of the day, if so, then we'll just leave it disconnected and get a cheap bluetooth unit to clip on the sun visor. Is this level of fault reporting the best I'm likely to get with the HFT and do you think that the replacement cost sounds about right (I nearly fell off my chair!).
Anyway, all thoughts greatfully received!
Best
Matt.
Best
Matt.
