Honda Accord 2.2I Ctdi
ben benjamin
ireland
accord
Hi all newbie here
I need to change the engine in my
Honda Accord 2.2I Ctdi 2008 will i have any problems with donor engine its the exact same engine will i have any problems with it programming issues etc can i just drop it straight in thanks in advance
F6HAD
Affiliate / Co-Founder
Staff member
Halifax
2009 Accord IDTEC
If it’s the same engine from a facelift then it doesn’t need any special programming as long as you’re using your original ecu. If you’re using the injectors from the new engine then they will need coding to your old ecu but it won’t stop the engine from starting and running.
ben benjamin
ireland
accord
ben benjamin said:
Hi all newbie here
thanks f6had so i gott change injectors so ?
