Hi, I’m new to this forum and just want to present my problem and hopefully find a solution. My Honda Accord 2007 2.2 i-CTDI won’t start. It cranks but no goer. RAC guy started the car by using easy start spray but couldn’t find any faults on his fault reader unit apart form the clutch pedal switch fault and told me that I have low fuel pressure on crank. I took the car to a local garage and they apparently did some tests on the injectors and they were fine, mentioned something about correcting the fuel pump and changed the fuel filter and that it should be fine. It was when I collected the car but when got home (about 15min drive) and parked up, I tested the start and it wasn’t great (was taking longer to kick in then normal) but eventually would start. Left it over weekend but on Tuesday when pulled up to the garage to get the diesel, the car would start again and an easy start spray was needed to start it again.
My question is: can it be high pressure pump faulty or one or more injectors leaking or the pressure release valve is faulty? Where do I start? I’m reading so many posts on this issue but don’t know where to begin and what to change first. It is also worth mentioning that the car was starting better while cold but really struggling or not starting at all while warm or hot engine. Now it won’t start at all unless I use the easy start.
Please help.
Chris
Please help.
Chris
