2.4types2003 said:
It went over the dashboard and we took the glove box out and replaced it. Everything else is working it has began to lock now and unlock when I press the buttons so alarm is all working but now it won't start lol which leads me to think that either it's in some sort of theft mode where it's cut the engine but then the radio is coming up with the code setting and all the immobiliser is working like literally everything is working as it should apart from the engine lol
hmmm, well there's another important module behind the dash, called the "Gauge Control Module", which has important functions between the B-CAN (Body CAN) and F-CAN (Frame CAN). If you look at the system diagram in #5 you'll see that the engine ECU is on the F-CAN, and the alarm-system units are on the B-CAN.
Before you get any other modules, get a cheap generic OBD reader and look at the codes from the engine ECU. You can also check the status of everything on the B-CAN, but a generic OBD reader will not do that, best is an HDS (Honda Diagnostic System, aka Honda HIM, clones are available on ebay for about £80).
2.4types2003 said:
It won't even crank it's just a loud buzzing noise when we turn the key to start and the fuel pump engages there is no crank what so ever
Where is the buzzing coming from, the MICU or the IMOES, or elsewhere ?
If it's the IMOES or MICU, if you can still get to the IMOES, check the status of the red/wht wire in the far right of diagram 26.
If it's from the engine compartment, it's probably the relay for the starter solenoid, or the starter solenoid itself, both of those would have got water in them.
Finally, are you sure that the battery is fully charged ?
