hondata flashpro fot CL9 at long last!
BlamesCL9
Kent
CL9/CW3
http://www.hondata.com/flashpro_tsx.html
Finally Something that will plug and play for CL9's! BUT! this is only for the US right now, and you need facelift ECU. But im sure sooner or later it will be coming over for us euro guys!
Very interesting ;)
Hondata doesn't make for Euro CL9 - we have different ECU's. Only one option is to use ECU from Acura TSX, question what errors it show.
That is correct for now! but in time i would think hondata can make one for the euro version.
not possible, believe me ;) I had this idea log time ago and had chat with Hondata owner Doug ;)
Our 06-08 ECU's 37820-RBB-E05 are different from TSX 07-08, we don't have full CAN bus support as TSX ones.
BTW I have working K-Pro (CL9) solution for sale if anybody interested, only no cruise and VSA available.
Hondata only had the reflash and harness to run kpro , but as u say takes away the cruise and VSA, which i defeintely do not want for this reason!
And its been along time since hondata did anything for the TSX, they even discontinued the harness. And now they have the Flash pro which runs on the ODB2 port and keeps cruise, and VSA.
Jsut hope, they can figure somethong out. keeping cruise, VSA and able to map the car will be the best thing!
Not exactly the same thing, no tuning/programming, but could be fun http://www.plxkiwi.com/
This isn't really new news, Vaikis is right, its down to the lack of CAN on 7th gen and implementation of Cruise/VSA.
We can tune the UK K24, but its not an OBD solution - the ECU needs to come out and be split open to access the maps.. If you've spent enough time looking at Hondata, as impressive and clever as it is.. it is actually a series of very clever vector and signal multipliers that manipulate the maps to achieve the power gains. So essentially it tunes outside the map areas in the software. This is because the maps are not accessible via OBD. The only way to tune the maps as you would in any other vehicle application is to split the ECU.
We are still willing to tune a member car for £300 if someone is interested - one time offer only. Check the Premier Tuning forum.
Well seems like there will be more than 1 or 2 options!
http://www.tsxclub.com/forums/heeltoe-automotive/56381-hondata-flashpro-out-but-competition-around-corner.html
And best thing is, it will work on 03-05 ecu's and plug straight in OBD2. So just have to wait til they test it on a euro CL9.
FlashPro works with Acura TSX 07-08 ECU in any Honda Accord 2.4 ;) No any check engine lights.
