> Not something you want to find out by running out in a diesel.
Mango - that is precisely why I ask the question!!
Okay I just found my receipt. My record so far is 60.80 litres (of BP Vpower diesel - which cost me a full £91.75, I may say).
So I actually had a full 4 litres left.
By my reckoning that's about another 36 miles - yikes yes, that really is a bit tight.
Incidentally all this stuff about fuel filters, I only half believe. All smacks a bit of urban myth.
I mean:
A. Surely when the tank is say 3/4s empty, the fuel will slosh about stirring up any dirt in any case. And if it's stirred up it will end up being sucked into the fuel filter, no?
B. Also isnt replacement of the fuel filter something that happens on servicing in case too?
C. Even by your logic, if I do it regularly I will clean out the tank, which is a good thing. :^)
D. Sometimes you absolutely need to know what your car is capable of.
e.g. When driving through the West Highlands late at night - nearest open petrol station 90 miles. I need to know will I make it? (or do I need to turn back and drive another 20 miles?)
e.g. When catastrophically late for some important engagement.
In the end my car is my servant - my tool not and not my God. Yes it shouldnt be abused, but in the end it is there to be of *use*.
But I do concede that may regret these words. What exactly are the symptoms of a clogged fuel filter?
How's about lots of smoke visible in the mirror in the headlights of the car behind - particularly when you first accelerate? (!)
So far my oil consumption seems extremely small - but all that smoke is slightly worrying.
Fwiw, if I driver carefully over mostly motorway driving, I am getting about 50 MPG according to the onboard computer.
If I drive at a 70 on the speedo (65 on the satnav) then I seem to get about 55-60 MPG (depending I think on wind/weather conditions).
Mind you I am highly suspiscious those MPG figures in reality.
Calculation: Suppose I put a sensible 55 litres in.
Divide by 4.54609, get me 12.1 Gallons
If am getting 50 MPG, then I should be getting 604 miles, and I'm pretty sure that I'm not getting that!
(And if I put 60.8 litres in that would be 668 miles...)
Anyhow, I shall start noting actual mileages between fill-ups more carefully. Watch this space.
J
