Jon_G
No Longer Active
Some fuel will drain back, but it can't all drain back unless there is a leak somewhere on the fuel pipe/filter/hand pump up to the intake side of the fuel pump. But if there is an air leak then air will enter the lines back to the tank and cause long cranking to be needed when starting.
Doesn't explain the smoke though. As I said on the previous page, I think that could be a dribbling injector (likely to be the one that was emitting air bubbles on the leak back tests?).
