My first attempt, failed miserably. You know things are going to go wrong when the first thing you do is break the plastic puller on the dipstick. Managed to remove the metal hose on the front, where the EGR is blocked via a metal plate. Took the caps of the glow plugs and injectors, and the bolts to remove the cabling but got stuck on removing all the cabling, it's housed in plastic bits which are a pain to come apart. The cabling runs down the left and up on the right, without removing it I won't be able to remove the fuel pipes. So 60 mins into the job and after 1 hour later I out it all back together. Best left to a mechanic I guess.
Another problem I had was one of the bolts where the metal hose attaches at the bottom came right out of the bottom section instead of the nut coming off, some corrosion around the nut hence.
Ive searched and searched but cannot find any videos at all which show step by step process in removing all the parts to remove the inlet manifold.
