rivergreen
I'm wondering if anyone has experienced a projector go faulty?
One side dipped beam is noticeably dull, I've replaced the bulb and is still the same, so swapped bulbs over just to be sure and the same side is still dull. The front lens isn't foggy, and I can't see any condensation. The good side and the dull one look just the same looking in through the front. The bulb is seated correctly, and if lit up out of the holder seems to be as bright as it should be, so don't think there is a low voltage/wiring problem.
The only thing I can think is that the projector has gone bad.
Has anyone experienced anything similar?. I'm about to buy a replacement headlamp unit but thought I would join here and ask the members if I may have overlooked something?
