I would start by inspecting the exhaust mounts at the back mate. They could be perished. No this does not sound normal to me.
Also check how much the engine rocks when you turn it off by opening the bonnet and getting somebody else to turn the car off. It could be a knock on affect from there so problem may lie there. Do you have any more details?
When I owned a passat tdi that had an anti shudder valve which failed on mine and caused the car to really shake when turning off. Not sure if the accord diesel has an equivalent?
Something like anti-roll bar rubbers parished maybe? does this happen when you reverse stop and turn it off as well? Just wondering if when you pull forward and stop it raises the rear end slightly and then settels. I had this issue on my prelude and it was anti roll bar linkages which had failed.
Not wishing to scare you but it actually could be a knocking DMF. Do you feel a knock deep in the footwell when driving sometimes?
The exhausts are painted black and they will last a long time.
Do you get any clutch slip? have you got any warranty on your car?
As suggested previously check engine/gearbox mountings and DMF firstly.
Mountings usually cause knocking noises whilst driving with hard acceleration or deceleration using the gears.
DMF usually shows by knocking noises if you press accelerator and then back off again looking for slack in the gear train or vibration.
If all of the above proves not to be the case it could be a leaking injector.
Compression ignition engines rely entirely on the air being compressed in the cylinder reaching a high temperature, the ECU then decides when and how much fuel should be injected into a cylinder.
The injected fuel is in an atomised condition thus immediately combusts due to the high air temperature.
When we switch off the engine we remove power to the ECU hence injector pulsing (operation) ceases and no fuel is injected into any cylinders.
If an injector continues to leak fuel into one or more cylinders than symptoms likes yours could occur.
On start up do you experience that you have to turn the engine over for longer than usual and on start up a lot of black smoke is emitted?
If so these are classic signs of injector leakage as the common fuel rail loses pressure (hence cranking) and black smoke is unburnt fuel in cyclinder.
The DMF is covered under their warranty. I'll be taking it in a few days and I'll let you know what happens.
how did you get on? i have same symptoms, replaced DMF, clutch and driveshaft so far but still get a vibration at 1700-1900 rpm and a judder through the car when i swtich off which i hadn't thought alot about until i read this thread......
The problem was the exhaust rubber mount at the back shuddering. 30 second job to replace.
Great result Dharmesh,
Shows it was well worth the trip to HH.
Nice meeting you btw, did you ask about the headlight misting?
Here's a link to the posts on headlight misting for the forum Headlight Misting Posts.
From a quick look it seems the TSB was back in 07, although people seem to have had mixed success and mainly relating to pre-facelift
