mystery box under dash
Kaput!
BOLTON UK
04 accord tourer 2.0
I was just checking something in driver footwell and looked up under dash below steering wheel and noticed something that looked out of place.
Its a plastic box (cigar packet size) with a wiring loom heading off toward centre console and on other end it has a very long cable with a connector on end...all cable tied together to keep it in place.
It kinda looks factory fitted but untidy so im curious as to what it is? It is dark so i can take pictures tmrw if needs be but in the mean time maybe someone knows what im refering to?
Kaput!
BOLTON UK
This is the box with wiring fastened to it and the little plug on end 20201018_165143_compress19.jpg20201017_213954_022_compress35.jpg
Kaput!
BOLTON UK
Directly above brake pedal
mlkehunt
Norway
08 I-CTDI sport
do you have a tow hook? any markings, stamps or stickers other than CE(chinese excrement) or qc passed?
Kaput!
BOLTON UK
No tow bar and this thing does have a sticker with some sort of code/part number on the wiring harness that disappears into centre console area.
I will investigate further tmrw once daylight returns and pull it apart for some better pictures.Btw i did a google search of said information on sticker but returned no results.I can ***ume its some sort of aftermarket fit just wish i knew what....may actually be something useful lol
Richard B
Australia
2006 Tourer
Open it up and see is there are any codes, brand names or version numbers on the circuit board. Also get the codes of any IC's (the larger the better) on the board.
qc2
london
2.4 Exec Auto
I think I've found the same thing under my armrest. It's the factory add on Bluetooth unit installed to the a pillar, this is the brains of it. Just disconnected mine and now installing a grom audio unit instead. Previously removed a similar one from my frv also.
Kaput!
BOLTON UK
That makes sense! Ive had no time to investigate further but i will get some better images tmrw once ive pulled it all apart
Kaput!
BOLTON UK
If
If you are able can you take a picture? Could help me confirm what i found
qc2
london
2.4 Exec Auto
I disconnected mine and it was definitely hookedup up to the control unit on my A-pillar. I said factory Bluetooth, I meant Honda/dealer as these must've been dealer upgrades which explains the different locations they seem to appear in.
Kaput!
BOLTON UK
Ta very much that pretty much confirms what it is.I will pull mine out tmrw to check whats going on? You are probably right too given the random locations ours are located.It also looks as though mine was fitted but never used as the wiring is still all cable tied together.
So to get it working what needs to be done?
qc2
london
2.4 Exec Auto
there's nothing special about the system really, does calls only and controlled totally from a panel bolted to the A pillar.
i'd guess that yours was a working unit and an owner before you had removed it. i haven't removed my control from the a pillar, as the installation leaves holes and would rather not have holes in its place. if yours is missing with no tell-tale holes in you a pillar trim, the trim has probably been replaced as part of the removal. i highly doubt that these were part installed an not used.
aside from this box, the loom will run to the stereo and much like a parrot, will interrupt the stereo for calls. a mic will be wired into the headliner/map lights area and wiring to the control on the A pillar:
Kaput!
BOLTON UK
Youve been a big help thanks again.Given that the control panel is missing and there are other bluetooth options i doubt its worth bringing back to life.I will still pull it out and trace wiring..just out of curiosity lol
