CG8TypeReplica
Hi guys, recently acquired a 2000' Accord CG8 from my dad. Its powered by a 'mighty' F18B2, which in all honesty isn't that bad, especially for an 18 year old like myself. Having a few problems with it though that I hope you guys can help me out with.
1. Had 4 new tyres fitted today and just now went for a quick drive to the shop and I can hear a strange ticking/knocking noise coming from either the drivers or passengers rear side. The noise can only be heard when I'm moving, and as soon as I put my foot on the brake, regardless of how hard it is, the noise goes away.
2. Theres a rattling noise whenever theres large vibrations in the car. Definately sounds like metal, just wondering whether anyone knows what it could be? Sounds like its coming from the manifold cover or even the manifold itself, can these work loose?
3. The car LOVES oil. It goes through it like theres no tomorrow. I've looked around and underneath the car and can't seem to find anything which would indicate a major oil leak. I was near the exhaust flexi pipe and I did notice oil spills near the passenger's drive shaft. It wasn't major though.
4. Intermittently when I put my foot down, theres a strange sensation of minor acceleration and then a few seconds later I get full power. This occurs when the car is fully warmed up, enough oil and at least half a tank.
5. This ones hard to explain, but when going over bumps or around corners there's a strange 'wailing' or squeaking noise coming from the passenger's side rear. Only happens when I hit a bump or go around a corner.
6. The brakes are awful, but my dad swears he had them done 3 months ago. The pedal judders under my foot under hard braking as if the ABS is kicking in and then stopping.
7. And finally I saved the best till last. Where are the low beam bulbs !? When looking at the Accord from head on the headlights are split into 3. The quarters which are nearest to the front grille are where my problems lie. When I open the bonnet and take off the bulb cover there is only one bulb which can be replaced which has the wire going into it. I've replaced these with 2 different bulbs and they don't work. However, theres a little bulb in the corner of that quarter which comes on but only for the passengers side. The bulbs which I replaced do nothing at all. Anybody have a cure for this? Full beams work fine, the middle quarter comes on like it should, but the inner quarter does not.
Thank you very much for any help you offer guys, little car noobs like me appreciate it!
** Forgot to mention that the car has covered 132K, so it's not the newest horse in the barn haha!
