Guys when changing the coolant is it necessary to flush it with water? Also do you need to drain it from the cylinder head aswell? As there seems to be a bolt at the back of the engine near the oil filter which is listed as a drain plug.
I was just going to drain it from the radiator where you have that white plug. I also ***ume a washer isn't needed for this white plug? Although I bought a washer but I think its for the bolt on the engine.
