Now this all "chinese" to me but it refers to faults occuring without the MIL LIGHTS COMING ON.
Fuel and Emissions Systems Symptom Troubleshooting
When the vehicle has one of these symptoms, check for a diagnostic trouble code (DTC) with the HDS. If there is no DTC, do the diagnostic procedure for the symptom, in the sequence listed, until you find the cause.
Symptom Diagnostic procedure Also check for
Engine will not start
(MIL works OK, no DTCs set) 1.
2.
3. Test the battery.
Test the starter.
Bleed the fuel system. •Low compression
•Intake air leaks
•Locked up engine
•Broken cam chain
•Contaminated fuel
Engine will not start (MIL comes on and stays on, or never comes on at all, no DTCs set) Troubleshoot the MIL circuit.
(immobilizer indicator stays on or flashes) Troubleshoot the immobilizer system.
Hard starting
2. Test the battery.
•Intake air leaks
•Contaminated fuel
Cold fast idle too low
2. Check the idle speed.
Cold fast idle too high
Inspect/adjust the throttle cable.
Idle speed fluctuates
2.
3. Check the idle speed.
Bleed the fuel system. Intake vacuum leaks
After warming up, idle speed is above specifications with no load
(MIL works OK, no DTCs set) Inspect/adjust the throttle cable.
(MIL works OK, no DTCs set) Bleed the fuel system. Contaminated fuel
Fails emission test
(MIL works OK, no DTCs set) Inspect the catalytic converter. •Contaminated fuel
•Low compression
•Slipped/ broken timing belt
Low power
2.
3. Check the air cleaner element.
•Low compression
•Camshaft timing
•Engine oil level
Engine stalls
2. Bleed the fuel system.
Check the idle speed. •Intake air leaks
•Faulty harness and sensor connections
