No Headlight Adjustment
chesjak
south coast
Accord I-ctdi
I know there are a few threads on headlight adjustments but none answer the question.
I know how to adjust the up/down and left/right thanks to the UTube article but I can't.
That is to say that the left/ right on both headlights can be adjusted but when it comes to the left right adjustment on both headlights nothing happens when I turn the screwdriver both ways. The castellated nut turns but no adjustment.
Before I start what looks like a marathon job to dismantle the headlights, can anyone tell me what might be the problem and how to sort it.
Regards
So, for clarity, you have up/down adjustment, but no left/right?
The left/right mechanism is even simpler than the up/down one. But it has a limit, if someone has over tightened the nut, then it will spin without any further adjustment. Stripping the headlight won't help much here (and it's a major pain in the a**). How much is the beam out?
Hi Jayok
Thanks for replying
The left is not far out but could provide better illumination if it was adjusted right a bit. Both headlight l/R adjustments are not working so it seems that you could be right. It feels as if what you say has happened. I took the car into a Honda body shop a while back to have paint splashed rectified and they must have been the culprits.
When you say its a major pain in the a** - how come?
Perhaps I'll leave well enough alone.
Regards
It's a pain in so far as, splitting the headlights. You need heat and it's difficult to reseal. Honestly you are better off getting a set from a breakers.
Also if the l/r nuts have been over tightened then the plastic guide would have been destroyed. If the lights were separated you'd still gave to plastic weld or whatever the guide - not worth it Imo.
If you need better light output the get night breakers or similar - the default bulbs in the Accord are cack.
BTW- I ***ume you don't have HIDS?
