My car seems to have some sort of oil leak but am not sure where exactly it is coming from or if its a major issue. Basically few months ago when I did an oil change I noticed much of the underneath the engine and on sub frame etc it was covered in grease and oil, wiped it down a bit, few months on and today I changed the gearbox oil and I noticed there is oil everywhere from the engine side all the way onto the gearbox housing, and on the subframes etc.
The place where the oil pan joined the engine is full of oil, so it must suggest the sump gasket is gone? But I don't understand why its everywhere. When I checked the oil it was below the minimum marker dot, but I think it might be worth checking when its cold and flat and when its hot aswell,.
Would the oil light on the dash come on if it was really low?
Am just wondering if its worth replacing the sump gasket or are cars meant to leak a little?
