icewarrior
Hi guys, looking for some advice from the diesel gurus out there.
Picked the wife up from work tonight and within a mile the oil warning light came on. Car had been running fine until it came on. I'm check the oil level pretty regularly so i was certain i was not low on oil. Stopped the car and checked the level, and it was sitting around half way between the min and max markers. I let the engine cool for about an hour, topped it up to the max mark with some edge 0w-30 and tried starting it again. The engine fired first time but was sounding pretty rough, seeing as my dad's place was only about a mile away, i nursed the car there, trying not to go over 1300rpm (usually changing gear at 1100rpm) I did notice an occasional mechanical chirp coming from the car when coming off light throttle (this only happened after the light came on, car was fine before), i'm guessing the turbo was running dry so i will probably need to buy a new one very soon.
Checked the receipts for the car and the last service, with oil change and new filter was about 8500 miles ago, (i had planned on getting to national over the past few weeks to get fresh oil in but never got round to it).
Any ideas as to what could be causing this? blocked oil passage/failed oil pump?
thanks in advance for any replies
Sam
Sam
