Parking lights
Drejc112
Slovenia
Honda Accord 2012
Hi
My parking lights are dead, well just one. I know i cant get to them without removeing the bumper and headlights. My question is how much space is in there to put 32mm long led bulb?
Blippi
Manchester
Honda Accord GT ES
Tbh if you look at your main high beams you'll see the parking bulb in the bottom of the reflector tbh I think you'll struggle to get it in and out with out removal of bumper/lights.
csak1981
Scotland
Accord Tourer 8th Ge
I wouldn't bother with the long leds as they don't last and you'll be having to tackle changing them again and again. Get the Philips extreme ultinon 501 led in 4000k colour they are less yellow than standard halogen 501 bulbs and should be fine for mot.
These are what I'm running and i got them in without taking off bumper although passenger side a bit tight with battery in way. You would be better taking out battery to avoid dropping bulb as you'll need to work with your fingertips otherwise.
The leds are only slightly bigger than standard bulb. Try switching them on once you've got them in the holders before inserting into headlight and if they don't light they'll need flipped 180 degrees then insert into place
Drejc112
Slovenia
Honda Accord 2012
Thanks ! I planed to chanege them first without removeing bumper, its not a big job but still if it goes without it would be great..
Drejc112
Slovenia
Honda Accord 2012
No, just the facelift model, from 2012 they are all like that, as far as i know that is.
Blippi
Manchester
Honda Accord GT ES
In the UK the face lift model has the same lights as the earlier type s from what I've seen.
Drejc112
Slovenia
Honda Accord 2012
Dont know, i havent seen it . But it could be that they make diferent ones for diferent countrys. Mine was made for sweeden and than it was inported to slovenia. In US they had diferent lights for same model and year.
csak1981
Scotland
Don't think I've seen that headlight on any mk8s driving around.
Could you post up a picture of them up close during the day with lights off and on
Drejc112
Slovenia
Honda Accord 2012
On this link is the same model as mine, mine is 2012 year but are same model, if you look from 2008 to 2010/11 you will see that they have diferente lights, front grill is a bit diferent too , front bumper goes up in between the grill and headlights, pre facelift model has larger grill that goes from one light to the other, no bumper in between .
This is link for 2008 year
Blippi
Manchester
Honda Accord GT ES
I'm guessing these where fitted to European models. In the UK the facelifts have the same as the preface minus the orange indicator lense which are then clear
