Nas80
Right no end of searching has proven fruitless in my quest for an answer
I followed the guide for the Nokia install thread.
1. On the sot 047 lead and the "to the radio" lead which connects to the set 047 side going to the amp.
the plug from parrot isn't corresponding with the iso plug. Instead of the purple grey green and white speaker leads the parrot iso plug will only go into iso socket for power wires instead of the speaker iso socket.
2. My standard premium audio with sat nav is giving no output to the speakers. But the parrot is working as it should be. But it sounds ***** as I don't think its using the internal amp. I think I've blown a fuse. Which one is it for the amp and n00b question. Where's the fuse box??!
3. In the thread with loads of pictures matey did he says to plug the pink wire into the top row fourth from he left. In the autoleads guide which came with the cable it says bottom row fourth from the left.? So which is it top or bottom row?
4. What leads do I need to facilitate the use of the standard amp. I see there are a few. Has anyone made this stuff work properly?
