John M.
Well the latest update now with 98,000 and exactly a year since I got her. I've done 14,000 over nine months ( the car was unused for a three month period) and I've really had no problems to report overall. I'm still getting between 32 & 35mpg along with a half litre of engine oil per 1500 miles and I've got to admit I do rev the nuts off it on my weekly round trip of 300 miles which consists of plenty single lane roads and a lot of slower moving traffic, so happy with the figures.
I've changed the fuel filter for a Blueprint one that I had sitting the boot of the car since Nov last year! I'd bet the filter I removed was the original as I cut it open to have a look at the paper itself and it was fairly black also it was genuine one too. I've also replaced the o/s/r hub ***y, the bearings were just starting to go, the brake caliper was slightly sticking on the o/s too and the pads were badly worn, fitted Mintex pads at a reasonable €27/£23 delivered, along with new stainless retaining disc screws. It could do with the rear discs being replaced also, I'd say they are original too, so just to keep the car going I gave the discs a very light going over with the angle grinder till I get a pair of discs. Between the slight hum from the wh.bearing (didn't increase when cornering), the slightly sticky caliper old pads & discs I had some odd sounding intermittent noises coming from the rear.
Also, I fitted two front Heko wind deflectors http://www.ebay.co.u...=item20d1f39588 , not a fan really but they have stopped rain water getting on the door card & all over window switches, also the door glass is staying much clearer & cleaner for longer .Tyres were required on the front too so, as winter is on it's way I decided I'd opt for something that's meant to be good in the wet. After reading tyre tests etc I got a pair of Avon ZT5's fitted ( I had ZZ3's before on my old Merc and I was happy with them) & I'm happy enough with these - time will tell. The price was reasonable @ €170/£145 including a 4x4 wheel alignment.
Now I'm waiting on two Blueprint rear discs, see here: http://www.ebay.co.u...460d45960c#shId
Next up is to investigate a light knocking noise coming from the suspension, I'm presuming it's either drop links or a suspension arm - hope it's the links. Other than that, touch wood all seems o.k..
