Passenger Power Window & Mirror not working.
Thanks a lot Richard
I will try this as soon as we get some decent weather here
Hi,
My passenger mirror is not folding (passenger side-right side in Eu). Motor is not working, can not hear its sound. Driver side is working great.
I removed door panel and this is the picture of mirror connector (#1picture).
I found spare mirror on junkyard but it has additional 4 wires (see #2 picture).
I suppose that my connector has 2 for turn signals (small connector on the left), 2 for mirror heater and 3 for tilting (up, down, right,left) and 1 for fold/unfold (changing the polarity).
Can somebody tell me what are those 4 additional wires?
Does anyone knows wiring codes for this connector and what is difference between those two?
#1
#2
Page 22-339 in the workshop manual has a diagram
Drivers side
Update on this topic:
It turns out that additional 2 pin connector is for mirror folding (on the picture bellow). I was looking at the wrong wires entire time.
Checked the wiring and changed the electric motor. Now mirror is folding as it should.
2013 EX iDTEC Yesterday I noticed that the passenger side window will not open. Regardless of switch used (passenger switch or driver switch). The passenger side mirror no longer responds to H or V movement commands and it wont fold either. It wont dip on reverse. The sunroof will not retract or tilt. The indicators do not blink when the remote is used to lock or unlock. The boot button does not open the boot when the car is unlocked. All of these happened at same time.
I suppose all of this is due to the passenger side window switch module?
37560-TL0-E12
Front passenger side window switch
If passenger mirror or window are not reacting to command (for windows either from drivers or passenger switch) it is clear sign of passenger switch module. What is unclear to me is how the boot button or sunroof is related to passenger module? I couldn't find explanation on this forum. Sunroof, boot and mirror buttons are located in drivers door panel thus have nothing to do with passenger door module...
Hi all, I know this is an old thread but I recently suffered the problems everyone has posted (mirror not moving, folding, boot lid not respondeing etc.). I took the switch module out (part number on mine was 35760-TL0-E11), cleaned it a few times and it worked for a few days then stopped again. Repeated process a few more times but ended up replacing with a unit from a breakers. The part number on the one I received is 35760-TL0-E01 so slightly different and it works great all except for the auto dip mirror when engaging reverse gear.
I'm wondering if anyone else had had this happen after swapping for an almost identical module and if I need to replace it with the exact same part number to get this function back?
My motor is a 2011 Wagon EX 2.2 idtec
I replaced defective part with exact same part and everything is working correctly again (including mirror tilting down on reverse).
Yeah, guessing I need to do the same. Ordered a brand new Honda original part for Amayama for about £120 inc VAT, way cheaper than from Honda direct. Just have to wait for it to ship for Japan now.
Surprising how many subtle differences there can be between very similar numbered parts.
Having exact same problem,same symptoms, must be a common problem and seems the breakers have found out what these cost new, as either the part is sold, or they want £120 for it
Hi. Can you give me the part number so I can get hold of one? I have the same issue-n/s front window, door mirror, sunroof and power tailgate. Thanks.
35760-TL0-E12
248 euro (part and shipping Oct 2024)
