Tomas sounds like you have a slow operating EGR and IMRC (quite common on higher mileage Accords) so even with EGR OFF, this will cause issues as the EGR has to be able to work for us to keep it closed. However those could also be historical codes.
Does your car actually have any warning lights on or is in limp mode indicating that there is a live fault on the ECU? the errors they've given you are more likely historical errors. So if you've had an error in the past, the ECU will remember them until the next time someone does a scan.
Have you not got a scanner for yourself? if they've cleared the errors off, I would suggest driving now until either it puts it into limp or give it a few days and then run a scan yourself and see what comes up so you'll get a better idea of what the issue is. I can't believe your car has all those issues at the same time.
They should also have been able to run some functional tests with their Honda Diagnostic System to check if your MAP sensor and turbo are working correctly, the EGR and IMRC can also be tested in a similar way.
Drop me a line, I'm down south next week, if you can get to me one evening I'll run a diagnostic myself for you.
